Fitting A Dash Cam To My 2006 Gs450h
I have just bought a dash cam to fit to my 20006 GS450h.
if i want to get the cam to play on the screen of the console how do i go about it and will it work? is there a facility on the console that allows it....maybe through the DVD play application??
also is it easy to get into the console to attach the other wires
would i be better to get an auto electrician to do it
thanks
It would be a lot of work for very little reward - consider the DVD player installed in the car only allows you to play it when parked up (hand brake on) - ok, there are work arounds to enable it to play while driving but it is a distraction.
The car cam would be the same I would imagine. Some car cams have screens attached but are so small that you struggle to see them when driving so the option gets turned off.
Ok, so just a simpe wire in to the ignition and the power/negative and just rely on the cameras own small screen for set up
I'm not familiar with the camera you have, but if it comes with a ciggy lighter type plug that will more than likely have a voltage regulator of some sort in it, so it's important to use that plug.
If you don't want to use the 12v/lighter socket on the car, you could hard wire (ign/earth) a trailing ciggy socket to plug into, then hide that behind trim. That's the way I've done it for dashcam, Satnav etc on various cars.
HTH
Malcolm
