Can anyone point me in the right direction for the front side light fuse on the GS450H just the fuse number would help. The hand book, and fuse box cover does not appear to list the front fuse, but lists the rear.
My rear side lights are working but the fronts are not. The bulbs have been changed, and a check for voltage at the bulb holders produces zero volts across the terminals, and to chassis ruling out a bad ground.
If anyone has a wiring diagram that would be most welcome.
John.
Edited by Britprius
Addition
I have now found the front side light fuse after much searching. It is located in in such a position in the under bonnet fuse box that it is almost invisible. Towards the front of the fuse box the is a separate box with four fuses laid on there sides with the tops just visible until you pull this box upwards out of the main fuse box allowing access to the fuses. It is one of these fuses that controls the front side lights.
I will add a picture shortly.
John.
