Guide To Remove Oem Hu From Is200.
I fitted the new head unit over the weekend.
What I found was that the front speakers (mid and tweet) work off one channel, but the rears mid and tweet are on separate channels - therefore you need a headunit with 6 channels - 2 for the front and 4 for the rear? Is this the case?
What I've done is parallel connected the rear mid and tweet onto the rear channel of the head unit. Not sure if this will drop the impedance too much though - seems to work OK so far without any cut out. Its supposed to be a 4ohm load on each channel.
Any comments?
