On my MK2 1998 GS I have a issue with electrical system. How it starts is usually the auto headlights don't turn off when closing the door. And then the electric mirrors and central locking and footwell lights don't work. I have found out that if I take the 5 amp fuse from the passenger side which is ECU and then put it back in its solve the problem. I would like to get this sorted out as it's a inconvenience. I haven't tried the new 5 amp fuse yet.
have you checked that the door switch is not corroded making bad contact happend to me on my gs300 many years ago took out switch cleaned it and the problem was solved
