RX400h 2005 Steering
Also tyre pressures.  As I understand it, self centering is caused by all the parameters that make up steering/suspension geometry and I would not have expected this to have changed significantly to make a great difference.
I'd check either if the bearings at the top of the front strut are seizing or if the suspension bushes have worn and changed the steering geometry. The steering rack itself could be faulty as well. Needs investigation unfortunately.
