Yes you can fit a space saver but the plastic tray and it's cover will have to be removed.
I used the spare space saver from an IS250 saloon and made up a new cover for the wheel well out of 6mm MDF.
I finished it off with a new Lexus boot carpet mat which Lexus offered specifically for the ISC. I sourced mine from eBay for about £60 if memory serves me right.
Hope this helps.
Dec.
Funnily enough Steve while my car came with the compressor and tyre goo it did also have the jack and the tool kit contained the wheel nut spanner.
I can only assume that you are advised to raise the punctured wheel off the ground while you apply the sealent.
I feel much happier knowing that I now have a spare wheel should the worst occur.
Dec.
