LS460 - Oxfordshire Lexus support
Hi All
I'm a new member here and about to pull the trigger on getting a used LS460. Just wanted to ask the community a couple of things.
1/ If you want to update the hifi but keep the ML amp etc is there any way of updating it so that it can take modern storage cards, Bluetooth etc ?
2/ Do you know any recommended specialist in the Oxfordshire for dealing with these cars ?
Cheers
Joe
29 minutes ago, JoeF said:
Hi All
1/ If you want to update the hifi but keep the ML amp etc is there any way of updating it so that it can take modern storage cards, bluetooth etc ?
Cheers
Joe
Lexus Indie Garages (1) (8) (3).docx
Hi and welcome
Check the car will run on E10 fuel or having said that most cars shouldn’t 👍🧐🤪
I don’t use E10!
Are you able to do any maintenance yourself?
The early LS460s cannot run E10 fuel.
https://check-vehicle-compatibility-e10-petrol.service.gov.uk/manufacturer/Lexus
  • IS250 2.5 litre V6 with engine 4GR-FSE made between August 2005 and September 2007.
  • GS300 3.0 litre V6 with engine 3GR-FSE made between January 2005 and September 2007.
  • LS460 4.6 litre V8 with engine 1UR-FSE made between August 2006 and September 2007.
    These models, and those produced before 1998 should continue to use E5.
