Snow Foam By Hand Sprayer
Hello to one and all. Snow foam car washing . I've ditched my power wash it's  gone to my son in law 4 car family to much hassle for me at 74yr old . Manufactures link  https://www.iksprayers.com/en/
If you do purchase make sure you get the snow foam model as they manufacture different sprayers . It comes with 3 inserts  I use wet insert grey you have to unscrew the spray head it's in the instruction manual . The 1.5 model I have will snow foam my Lexus NX  I have to pump the spray 3/4 times ( 30/40 times total)   to foam the whole car . The benefits simple to use AND ONLY 30/40 millilitres of snow foam product  . I use bilt   hamber snow foam
https://bilthamber.com/product/auto-foam/
My purchase link  from eBay
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=GOIZPER+IK+1.5+FOAM+SPRAYER+FOR+CAR+VALETING%2C+DETAILING%2C+CLEANING%2C+DISINFECTING&_sacat=0
I have posted this simply because I find it so easy now to snow foam my Lexus NX
 I have no connection with any of these links . I hope it helps someone as much as it has helped me
Take care
Take care
Looks a great solution Phil, thanks 👍
  • 4 weeks later...
Thanks for the recommendation Phillip. I went on to purchase the IK Sprayer PRO 12. This model is more expensive as it has a larger capacity and can be pressurised through a Schrader valve as well as the in-built hand pump. I have used it twice now and appreciate that I only have to repressurise it twice to cover the whole vehicle. The Pro 12 holds enough liquid to do the whole car too.
I went for Maxi Suds II from Chemical Guys on the recommendation of a What Car review. It doesn't foam up to the extent that you can't see the colour of the car (as appeared to be the case in some photos) but I'm not disappointed. Despite not following the instructions, all I did was spray the foam onto a car that hadn't been washed for 2 months and then rinsed it off, the results were very good. More significant was that it was very easy. Spray foam on, rinse off.
