Sign in to follow this
DaveEllen
Racelogic Launch Control
Just back from TDi.
Got the Racelogic fitted & Tony managed to get the Launch control working for me....
so press the button engage 1st floor throttle & hold it there drop clutch and off u go.............
truly amazing :lol::lol:
So any improvement on the 0-60 time ? B)
Would expect so as all I do is hold the throttle down dump clutch as orf I go.......
need some new rear tyres already :whistling:
How close to space did you get.... ?
Are you planning to be first man on the moon Dave? :offtopic:
I was near Tdi today, should of known to pop in and see it before you did :P
How does it work and why would one need it ? :unsure:
TDi could well stand for Tony (Maz) and Dave Investors... You guys do sooooooooo many mods there....
Great place though... Will be shopping there shortly.. Hope Mark can keep my purchase a secret.
If its the same as Kaveys then ......no!!!
The racelogic traction control replaces the std lexus traction control. you have dry/wet/20%/15%/5%/Off settings.........it works on the ABS sensors not the throttle thingy on the Lexus so you can have more control.
The launch control is a bit more dosh and what you do is press a green button......floor the throttle and the revs hold at 4500 rpm dump the clutch and off u go.............it can even be set up so u never have to lift off the throttle when changing gear :whistling: (not done that yet)
u getting a pulley upgrade young steve :whistling:
I have a Blue button to press before I floor the throttle Dave... :)
This Race Logic sounds good.. traction as the oem one is overly sensitive when on.
Kavey? big Pully? emmmm ....
I've got a shiney orange one :blush:
will try the launch control with it 2morrow :winky:
Nah i never said Kavey had a big pulley.....he had something else but i'm sworn to secrecy :whistling: dam nice bit of kit though!!
how long will your clutch last with this dave?? reminds me of a story about a guy with an m3 - used the launch control often - clutch went bang back to dealer, they did the data down load " sorry sir but u have used the launch control more than X times - your bill is £xxxxx" LOL
not long ! But as with theNOS if you're sensible things will be OK.
Getting uprated clutch soon when the all steel bits are done
How much is the button (and the rest)? :hehe:
was about £1000 all in.............dont think launch control is a DIY job as Tony was setting it ip on his laptop while i was driving it
