Not all doors unlock when opening car
Hi all,
I've had my 2010 rx450h for many many years and it has always unlocked all the doors when I have put my hand on the drivers door handle.
However for some strange reason it has recently only started opening the drivers door. This means if I want to get into a rear door I now have to open the front door and press the button to unlock all the doors (where as before I just touched the front door handle).
I am expecting I've changed a setting but cannot work out how to change it back?
Thanks, Scott
Thanks, I ended up reading the manual for the newer version than mine, unintentionally to begin with, and saw that it says to hold both buttons on the key at the same time and it will change the door touch option. I then tried this and found it worked on my car even though the manual for my car year doesn't say anything doing this.
2 hours ago, Spock66 said:
It's an anti hijack feature so if you are parked in a dodgy location late at night someone can't dash up and jump in one of the other doors.
I found it incredibly annoying when putting the kids in the car that I had to unlock the car then open the drivers door, press the button to unlock all the other doors and then open the rear door to be able to help my child into their seat. Being able to just unlock the car and open the rear door made it 1000% easier.
On some cars I've owned in the past, you pressed open once to just open the drivers door, and twice to open all doors and boot.  Have you tried this?
Ged
