2003 RX300 sunroof drain holes are there 2 of them or 4?
2 hours ago, 2003RX300SE-L said:
Hi All,
I’ve seen conflicting info on whether there are 2 or 4 sunroof drain holes on a 2003 model RX 300. Does anybody know definitively if there are 2 or 4 of these drain holes?
Just sent a PM to you that may help, Richard.
The two at the back are tricky to get at.
I'm guessing you are looking to make sure they are clear with some strimmer wire?
If so, I found the two exit drains under the car and pushed the wire in from that end.  Just seem easier at the time!
