Windows
Andy29
Anyone help please; I was driving along when I realised that only my drivers window goes up and down. I've tried them individually and via the drivers control, but nothing works!? TIA
It sounds like you have inadvertently pressed the window control lock button.  This stops the passenger windows operating as a child safety precaution.
This will be explained in the Manual, but if it’s the same as mine, look for a bank of three switches in the driver’s door, just below the mirror adjuster.
The largest of the three is the window lock button.  See what happens if you press it!
Or if it isn't the case that you have accidentally pressed the lock switch, has the Battery been disconnected recently? If it has, from my experience, you will need to fully open and close each window using their individual switch before you can do it again from the drivers control.
