Right peeps. I have a 2009 is220d. And for some reason keeps going into limp mode. I can drive 100 mile to work and will be fine. Then when I come back go into limp mode twice. Please help
6 hours ago, Carlh said:
Not yet was just asking around first to see if anyone has any ideas
Without a read out there could be 1001 guesses. Won't be helpful
Is it actually Limp mode? By that you should have Engine + VSC Lights... I don't remember if IS220d also says "LIMP" on the display, but certainly you must have engine lights.
Or is it just down on power? Because the later could be caused by blocked diesel filter, or blocked air filter or some other issues which may not give fault codes. The actual Limp mode will give fault.
Well that is more like it loss of power. But I call limp mode as won’t go above 2000 revs
Is it more like hard limit i.e. car revs freely up-up 2000RPM and then just sits there or is it more like car seems to be unable to reach more than 2000RPM?
I mean it could be something like dead throttle body, but that should give fault code. Or it could still be something related with fuel filter or even fuel pump pick-up... it sucks something up and gets blocked.
Do these not have like "DPF Cleaning" dash light of some sort? Some diesels are good and they tell you when it's cleaning the DPF, some diesels even let you clean it manually like a Land Cruiser.
When was the last time the EGR valve was cleaned?
If not in a while, then a relatively easy first step as it will most likely need cleaning anyway.
Nope, the only way to manually start a cleaning cycle is via TechStream.
Usually you can tell when a DPF cleaning is running as lots of smoke comes out the back!
.... diesels!
Wouldn't blocked EGR trigger some light, like DPF efficiency or something along those lines, especially if car can't even get over 2000RPM. Also wouldn't EGR be just increasingly more and more sluggish, rather than on-off "limp"?
I meant actual fuel (diesel) filter, not blocked DPF. If DPF would be blocked to this extent where car does not run above 2000RPM, then I would expect it would trigger the fault code for "DPR performance below threshold".
Mostly likely, but if there are no codes showing, then who knows?
At this point, you would need TechStream to see what is going on and run some diagnostics.
