  • 9 months later...
Hi !
I have installed these on my 1993. A little modification to get the bulb connector in place...a dremel is all you need :D :
Ebay site
Trying again :duh: to put in a link to pictures:
My Webpage
The connector holding the bulb did not match this new lamp, so You have to modify the 3 openings in the lamp for it to fit. Done in 10 minutes :)
So...Where can I now find a clear bulb that fits :huh:
Thanks Arvid.
Any pics of the finished article and what you had to dremel away?
Tony, If you still want a set, I'll share the postage with you, from the USA.
How about a Group Buy?
Does the forum Admin organise that?
Hi !
I have a set but it don't fit my model :angry: , they are a bit wider and the keyhole doe'snt match up with mine. US and Japanese models should fit these !
Link to picture:
Clear rear lights
You can get mine for US$ 125 + freight...My loss...Your gain :tsktsk:
Regards
Arvid
