I've noticed the last couple of day when I insert the key into the ignition and the steering column moves into place it squeeks, well more of a screech really. It's only when moving in the up/down plane not in/out.
Is this common, Do I need to be worried and can I rectify it e.g. remove covering and re-grease perhaps? :blink:
Doesn't always do it, not sure maybe only in hot weather, will monitor - maybe metal expansion?
Indeed it is a known problem. There is a TSB for it. Only happens on 1998-2000 models. As it only gets hot enough 3 days a year in the UK I never looked into it further on my old GS, just put up with it.
