Removing Emblem
Mine just had an L shaped backing piece behind the grill held in place with those little star clips. I managed to get a long flat blade screwdriver down there and lever them off.
The plastic shafts they clip onto are very soft tho, thought they might break
no backing plate :unsure:
I'll go try a screwdriver.
I did think of this, but again was worried about breaking the mesh :blush:
I just used some long nose pliers and forced the washers off
that was what I did in the end Brett ;)
I thought the pins had to come out though - hence my hardship :blush:
Once Mat pointed out the pins stay with the badge, I just loosened the washers and used a set of pliers to work them off.
you tools? :lol:
