Toyo Proxes T1 R's Standard 17" £97 Fitted
COLD
Hi guys
Just after a few thoughts from you. I have read loads of links on tyres but still cant make my mind up on what to get? Links vary from Toys's being fantastic - Toyo's worst tyres ever?
My Is is totally standard so I dont need anything too fancy. Running Dunlop Sp9000's now but only because they were on the car!
cheers
:duh:
yes chris. Ian at alpha seems a nice guy, not sure what to do now though?
You opted for the khumos then? would you have had these if you were not selling you car?
probably although not seen them yet, must admit i've been really pleased with the Bridgestone's but they are just to expensive and i only had them originally because the were the same as the tyres that came from the factory
what !? i just ponied up 130 a corner with fitting and balancing  :crybaby:
on the plus side the tyres rock. serious amounts of grip on them. recommend them do i.
:blink: What? Which tyres rock? Are you on about the Khumos or the Bridgestones at £95 each?? :blush:
