No Ignition
icecrew
Hey guys,
Was not sure which section to post in, so I'll try here. I have a friend who has a 2002 Altezza GXE10 with automatic transmission. He has a problem which seems to have even the local Toyota dealer stumped. He gets in, turns his key, the engine will turn and turn, but it will NEVER start. :-O
Where should he start looking?
Thanks in advance...
...has the battery been disconnected?  If so, try leaving the key in the "run" position for 6 minutes, then try starting.  This is the case on the Mk.2 GS.
it's rare for this to happen and you can tell if it is the problem because the security light will not go out when you put the key in the ignition.
