prento 0 Posted December 23, 2005 Share Posted December 23, 2005 Hi Guys, Can someone tell me just where I can locate the fuse box that houses the fuses for the rear park lights :duh: I have searched this car hi and low to no avail. I have an 99 Altezza and have so far located 3 fuse boxes (2 under the hood and one on the passenger side below the glove compartment almost next to the floor mat). Quote Link to post Share on other sites
Mr Morse 0 Posted December 23, 2005 Share Posted December 23, 2005 Hi Guys,Can someone tell me just where I can locate the fuse box that houses the fuses for the rear park lights :duh: I have searched this car hi and low to no avail. I have an 99 Altezza and have so far located 3 fuse boxes (2 under the hood and one on the passenger side below the glove compartment almost next to the floor mat). ← Should find it in the footwell fusebox Quote Link to post Share on other sites
Steve ( West Mids ) 5 Posted December 23, 2005 Share Posted December 23, 2005 There's a fusebox in the driver side footwell too. Quote Link to post Share on other sites
prento 0 Posted December 23, 2005 Author Share Posted December 23, 2005 Ok thanks guys...will have a look when I get home....I need to have sorted so i can hit the town tonite without the cops pulling me over Quote Link to post Share on other sites
MrADeveci 1 Posted December 23, 2005 Share Posted December 23, 2005 Have you tried changing the actual bulbs? Quote Link to post Share on other sites
Gofaone 0 Posted December 26, 2020 Share Posted December 26, 2020 Which fuse to check if the hooter is not working Quote Link to post Share on other sites
PCM 624 Posted December 27, 2020 Share Posted December 27, 2020 15 hours ago, Gofaone said: Which fuse to check if the hooter is not working This? Quote Link to post Share on other sites
ColinBarber 1,897 Posted December 27, 2020 Share Posted December 27, 2020 19 hours ago, Gofaone said: Which fuse to check if the hooter is not working On the Lexus IS200 / IS300 there is a 10A fuse labelled HORN which is in the engine bay fuse box. The horn itself is activated via a relay so that would need checking too if the horn isn't working. I imagine the AS200 and RS200 Altezza are the same. Quote Link to post Share on other sites
