Noise When Turning
Is it when manouvering to park etc - at slow speeds ?
If so could be brake pads are low and clonking when applied - mine did this as have others - new pads sorts it.
ya it is like that fella
will get them looked at cheers
If your tight like me, and have a bit of mechanical knowledge they are easy to check and change
I got the instructiions from here : link
Cost me about £20 for pads and did it in my lunch time
Could also be the lower ball joint! Put on full lock and inspect the rubber gator for tears/ crack as its a sealed unit and if u got a tear in the gator, grease could have leaked away over time.
Pads is a good place to start though. You can order new pads and might be worth investing in a new shim kit while your doing the pads.
