Overdrive Light
MIN007
Hi All
Can anyone help ??. Have a 1991 LS400 and the overdrive light starts flashing after driving for about 10 minutes. Kickdown normally doesn't work once this has happened but if it does, revs go sky high .... 6000+.
Gear change is normal though. Any ideas what this might be ????????.
Id get the auto fluid changed for new and see if that cures the problem,the fluid could be thin and causing problems...if that fails then it could more of a bigger problem of worn cluches or something in the autobox making it slip by the sounds of it..
Good luck
Chips...
