1st Cat Gone, Woohoo........
Ahhhh__Aristo
Got the first cat removed today (well cut open, horrible restriction catalyst removed and then welded up)
Oh boy what a difference, highly recommended. :D
If you forgot you had 2 turbos, this reminds you they're still there.
(sorry forgot the pics as was spur of the moment)
Don't know :doh: boost gauge is next on the list (you can tell my hearts not in selling it :D )
Still got second cat and stock exhaust, so imagine only a little more, but they certainly hit harder.
Made plans for a custom exhaust aswell today, as looking at the stock system, it's a little worse for wear, so easy to talk yourself into things :D
okie dokie, they have HKS stamped on them, they have the same dimentions as the hi-power exhaust system part number 3203-EX003. I couldnt read the rest of what was written on them because i was the wrong way round lol. im looking for 300 + P&P (about 40 pound) I'll need a bigger system when i get my single turbo kit fitted next month.
Yep - Happened to me
After playing with different settings, mine starting cutting out suddenly like I'd run out of fuel, tweaked down a bit and everything ran fine, thank goodness.
The difference it makes in removing only 1 cat is quite good, and you can get through the MOT without any problems aswell.
