Ok my dash board flickers on and off but stays mainly off - and also when my heads are turn on the centre column goes out and i dont understand why?
i took it to someone and he said yea no problem - to find he hasnt a clue great
please can people help
thank you
mat
Its a common problem with the LS400.Have a look through the LS400 section theres some answers and fixes on there,for even more info have a look on the US site under the LS400 section
http://us.lexusownersclub.com/forums/
Or try giving Swift breakers a call they might have a good Secondhand dash if you dont mind changing it over yourself..
Swift 01903 856568 they can post it to you and guarantee most things for about a month..
Hope thats of some help..
Chips..
hey chips you have helped me a few times now so i thank you.
ive tried looking and cant find nothing on the dashboard side of things - i understand its a common problem but im needing help lexus said it would cost over 1000
cheers mate
thank you
mat
Hi Mat,
Try this link to the US site if you are OK at soldering fine if not problems
The parts cost nearly nothing if you have the skill to fit them.
http://us.lexusownersclub.com/forums/index...=ST&f=3&t=4929&
Cheers,
Steve
Yep, Maria and Derek at DsAutos sorted mine out a couple of years ago.
Chris Vince on here also sorts them out, as has been said, its just a few pence in bits but a whole lotta knowledge!!!!
(as with most things!!)
boys ill do that soon thank you so much for your help what stars
mat
i had this fault on mine and lexs dealer quoted over a grand for the sort.... i sorted it my self for 12pence and a hour of my time 12p was for a cap and the time was taking instrument cluster out and soldering new cap on sorted dash and centre console if you look bak into my posts the fix is there somewhere under blinky dash
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
