91-92 2jz-gte Info
Ahhhh__Aristo
I'm about to get my valve stem seals ordered, as they've started to go, and noticed a few parts from the early 2jz-gte are different to the 93 onwards ones.
Like the valve stem seals for example.
Not sure what the difference is, but has a different part number.
Just thought I'd post it up, as might save someone the hassle of getting the wrong parts if they're ordering from the j-spec supra part numbers.
Seal are the same from 91-97. I would have to check 97 onwards.
Same physically??
As there are different part numbers for different years
