Vsc Activates After Fitting Goodyear Eagle F1s
maneesh
In the 8 months I have had the car, the VSC activated maybe once, despite me driving pretty fast.
I got the geometry fine tune by Dr Bones (which has made the car very responsive - thanks!). He also fitted the Goodyear Eagle F1s on the back, replacing the old Pirelli P Zeros. The car is now very grippy from the rear around corners. I can really chuck it around.
Only problem is that on the quick spin from Dr Bones' place, the VSC activated twice in just a few minutes.
Dr Bones and I reckon that the Goodyears offer so much extra grip that the tyres outperform the factory chassis setup and hence why the VSC activates. Plus, my previous setup was a drift type setup, so now the geometry is factory standard again.
Any comments?
Tyres take a couple of hundred miles before they get up to spec in terms of grip. If I were you I would take it a bit easy untill after 250 miles since the new tyres were fitted. Anything else before that will be asking for unpredictable sidways action!
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
