This Thing Can Save Much Fuel?
calvinlex
Does anyone have any experience in using those fuelsavers- Powermax or Fuelsaver device which cramps on the fuel supply line and uses magnetic field to reduce fuel consumption ? Are they of any use and is it easy to install by amateur- where is the fuel line ? I'd appreciate any help please.
If you do decide to get one, make sure you park the car under the apex of a pyramid and wear a copper bracelet on your wrist and some crystals round your neck while fitting it. :yahoo:
As a general rule, if something says it works by using magnets, and isn't some sort of motor, then it's a load of mumbo jumbo.
Spend the money you were going to spend on the magical magnet more wisely, perhaps on something that really does work, like anti-ageing creams or having your fortune told or some petrol :excl:
