What Tyre Pressures Are You Guys Using On V300 Mkii?
aido
Just going to check my tyre pressures today, just wondered what figures you guys are using - are we ok to use the figures for the GS300 / GS430? Just wondered as the V300 is quite a bit lighter than those.
The GS300 figures say to put higher pressure at the front, the GS430 is saying around the same, I'm guessing the GS430 figures will be more applicable due to extra power?
Any advice appreciated, thanks in advance :)
Cheers buddy, might give that a go tomorrow, from what I read that will make the back more prone to skipping out but more traction, also less mpg, the pressures were all over the place, one of the corners was at 30psi and another at 36psi whereas the other two were at 33!
Seems slightly better now though, will let some air out tomorrow and see how I fare with 30 mate, thanks fella :)
I think I've got 18's running 225/45's on there at the moment, not ideal but hopefully should be better in the winter than anything wider!
It did handle great last night though, was much more composed around corners than it had been!
Thanks guys, all running nicely at 33psi, very happy with the car, just a shame the gritters and stuff are coming out now the weather is getting colder, will have to drive slowly for six months now :o
