Does anybody know the difference between a LS400 UCF20 and a UCF21 ? I have seen the series 4 LS400 in the UK as a UCF20 but a lot of the celsiors from Japan are UCF21. Is it just the air suspension or are there other differences ?
If I am not mistaken my understanding is:
LS400 Series 1 - UCF10
LS400 Series 2 - UCF11
LS400 Series 3/4 - UCF20 and UCF21
LS400 Series 1 - UCF30
LS400 Series 2 (from 2004 onwards) - UCF31
Sometimes is just useful to know this information when sourcing parts.
Sorry typo, I meant
LS430 Series 1 - UCF30
LS430 Series 2 (from 2004 onwards) - UCF31
It's a little confusing as there are 4 model codes and 3 LS generations these are UCF10,UCF20,UCF30 AND UCF40.
The other codes you mention are designated for non USA/Canadian markets and are UCF11,UCF21,UCF31 and UCF41.
I think!!!
Have a look on this link which fully explains the set up
http://www.lexls.com/info/lsgenerations.html
Cheers,
Steve
Cheers Steve,
I think your right, this helps to clear it up for me. Different regions probably get a different UCF number depending on the spec for that region. I know for sure that R or L suffix after the UCF code refers to left hand drive or right hand drive (e.g. UCF20R = right hand drive and UCF20L = left hand drive).
Also, I've noticed that according to the Lexus Bahrain and Lexus Arab Emirates website that their version of the latest outgoing (from 2004 onwards) LS430 gets a 332 Hp engine while the UK spec cars 'only' get a 278 hp engine... thats not fair :(
http://www.lexus.com.bh/showroom/ls/specs.asp
Thanks for the info.
Cheers Steve,
I guess fuel economy isn't a problem in these countries!!! :)
Although there was (is) only one model of LS400 in the UK, in Japan there were several versions of the Celsior with different specifications.
So the first digit is the series -- UCF1* = mark 1, UCF2* = mark 2, etc., and the second digit is the version.
Example:
http://www.cars-directory.net/specs/toyota/celsior/1989_10/
If you want ALL the toys, look for a C spec, F package :)
