Road Noise
robmitch
Hi Y'all
Quicky, has anyone experienced alot of tyre noise on their IS 200? mine has Firestones on the front and Federals on the rear, all TP's are correct, I have a feeling that it may be the Cheap Federals on the rear which are causing the problem (which disappears at about 85-90)
Cheers
Rob
It's normally down to what tyres you have on, some tyres are better than others at cutting down road noise.
Also dependant on the road surface.
If all else fails turn the music up :D
Yep i can do that
Cheers
