Obdii On Is200
Hoping someone can help me....
I bought the Informeter in Japan.
klick
Unfortunately it does not work on my 2002 IS200 german model.
My problem looks like this topic: klick
The Altezza (both with 3S-GE and 1G-FE) is listed by Greddy to work with the Informeter.
I have already tested some cars( all german models): 99 Nissan Micra K11, 2005 Honda Stream, ~2000 Mazda Premacy (with Honda used in the preferences of the Informeter) work well with it.
Pins used by the Informeter are: 1,2,5,9.
Pins on the OBD in my car are: 2,3,4,5,10,12,13,16
By the cig lighter Pin 1 of the Informeter is supplied with 12 Volts+.
But the damned thing always says: Communication error. Check manufacturer".
Does anyone know the differences in the OBDII-configuration Altezza/Lexus IS?
How can I get it work? E-mail to greddy is not answered yet :-( .
regards from germany
the 3s-ge altezza doesnt use OBD II...and neither does the JDM 1g-fe engined altezza
as was stated in the topic you have linked to.
the item you have bought is designed for the japanese market
  • 6 months later...
I've been looking at these recently and wondering if they work or not.
So can you just set it to honda setting without having to fit it in a honda first or does it auto configure or something?
Does it give decent readings? a/f etc?
I think my fault was, i never switched off ignition after changing the settings. So setting to Honda, then putting ingnition once off and on should work, even not sticked on to a Honda before :winky: .
Throttle-position (the throttle controlled by ecu, not the "position" given with your foot) and A/F-correcture are given out in Volts or Graphs. If you know the band of them, you can set min/max and get accurate readings. O2-reading is the nernst-lambda, so it switches permanent from rich to lean, isnt much helpful. A wideband-lambda is really better. A/F-C is only a A/F-correctur-factor, dont know what this really means and is good for.
With the informeter you can read out:
speed
tacho
intake temp
water temp
ignition
O2
A/F correcture
intake manifold pressure
You can define how it is shown, by graph, numbers, circle and needle. Peaks are also captured until you switch ignition off.
A similar unit is the Blitz R-Vit. This can (with a separate unit) show you A/F by wide-band and is much more effective than the read-out of the lambdas fitted by Lexus.
heres a video i made, accellerating from 0 to 170 km/h
klick 10,7 MB
