Ok So Whats Needed?
I've had my IS for a few months now and I'm starting to get a little power hungry! :devil:
I fancy getting a turbo added, although since proposing last month I can't afford to get it done in one go because I've got the wedding to pay for :crybaby:
So if i'm going to do it I have to buy it bit by bit. The main question I have is could someone list the components that I will require?
Would it not be possible to buy a full kit and pay in installments?
Good luck with finding the bits and look forward to seeing the post with the work in progress.
That is another option I suppose :)
start with a turbo
then a manifold to bolt said turbo to
then a downpipe from the turbo to the exhaust
decide on wether external or internal wastegate is going to be used
some sort of boost control
piggy back ecu to control the fuelling
boost guage to monitor boost
intercooler
pipework to suit intercooler
air filter
pipework to suit air filter
turbo needs to be suitable for the application
intercooler needs to be suitable for turbo/engine
i only know of one kit, and that is not just a bolt on job
search the forums and you will see
there is very little if anything off the shelf, so look at doing some engineering
once you have the turbo fitted, to get any real power you will then need to carry out internal engine mods
all in all a lot of work ......and money
good luck :D
As Barrie has said.. loads of work and money plus internals for serious power.
Start with what power you are after first and then you'll have to build a kit around that. Turbo size is a major factor for what manifold to get T2 / T3/ T4. Then wether it'll have internal or external wastegate (smaller will usually have internal anyway). Sourcing a manifold will be very hard too. There is a cast one that comes with the Prolex kit but other than that you will probably have to get one made.
Check out my turbo thread (more work being done) for more info. Plus it shows all the downsides to what is involved including how to blow 4 holes in your engine :winky:
