Lexus Pedal Set
OK so I took a look at thes pedals as the largest long plate looks far too long to be the clutch so I believe this is to be used as the foot rest. The smallest one is the accelarator, the mid sized one is the clutch and the wider one is the brake.....
I could be wrong but that certainly makes the most sense to me! :winky:
You have to remember the kit is for an Auto.
  • 5 months later...
Finally got these fitted on Saturday, will post up a pic tomoz
Hey Wozza if you still have the little one I'll fit it to my parking brake on the 250. :whistling:
This is what they look like fitted (cheers Simon :P) to my Auto IS200 covered in dusty footmarks
They may well fit other models including the IS250as the small pedal in the kit
looks like it is made for the foot/handbrake on the IS250
Several sellers on E-Bay selling what looks like an identical kit, 1 in U.K others in
U.S.A & Hong Kong, just type Lexus Pedal in search :D
How hard is it to drill the holes on the pedal? I think these look better than the standard lexus sport pedal.
They do take a fair bit of drilling, but it is a small hole,
so just make sure it's a good quality Drill Bit.
The Footrest on the Left is slightly too wide (designed for the IS250) so only 2 holes
needed to secure it and the Throttle Pedal has the linkage behind so only 2 holes
drilled in the Throttle Pedal on an IS200. (See pic)
They are however very firmly fitted and will not be coming loose.
Hope that makes sense. :D
  • 2 years later...
Just bought these off the bay, expensive (£55 )but I think they are worth it,
The Alloy seems quite thick and well finished.
Would like to know your opinions of the set , and suggestions required with
what to do with the little (spare) one ?
Took this pic this morning
Do they have it also for manual transmission with the pedal for clutch and if is possible to get the link for it?
