My New Altezza!
DaveRS200
hello yeah i just brought my altezza rs200 i love it to bits.drives superb and is very quick.
just got a few questions if any one could get back to me ???
can you wire a sub and amp throught the standard altezza head unit ?
and i have brought a hks timing belt from japan and was wondering if you have to change the tensioner aswell?
just added a few better pics!! needs a clean.
welcome to the site mate. lovely car. Amp and sub can be easily added to the standard headunit, but you need to buy a line level convertor which enables you to take the wiring off the woofer part of your rear speakers and you connect them to the covertor which has 2 rca plugs, which you can plug into an amp and then your sub into your amp. makes sense? Not the best setup sound wise but simple to do, convertor is available from Halfords or eBay
welcome to the site mate. lovely car. Amp and sub can be easily added to the standard headunit, but you need to buy a line level convertor which enables you to take the wiring off the woofer part of your rear speakers and you connect them to the covertor which has 2 rca plugs, which you can plug into an amp and then your sub into your amp. makes sense? Not the best setup sound wise but simple to do, convertor is available from Halfords or ebay
ok thanks m8 might try that. i would put another head unit in but i like the 6 cd idea.
do you know about the cambelt tensioner if that has to be replaced when cambelt is replaced? cheers m8
