Altezza Replacement Headunit
looking to replace the headunit on my car since I'm having the error - 1 problem
I already bought the fascia plate, I'm looking for a unit that can play both cd and md
the original unit came with a md player, so I bought a md recorder and blank disc to utilise this feature.
md are cool and are rewriteable
any suggestions are welcome
Md are old and out of date! Not sure if there is anyone that still makes md players for cars. i just have a Pioneer headunit that plays cds and mp3s, wma's. not much else you need
no md are not outdated, my car is a 2003 model and came with md
md just never made it in the west because of its cost,
it is still popular in japan and is of high quality
as does Alpine
Alpine MDA-W890
Features: CD/MD in dash player. Disc and station title memory. MIX [shuffle] all (CD/MD?). 24 station presets (12FM, 6AM, 6DAP). Local/DX selection, up/down seek.
Specs: Amp: 40Wx4 (19Wx4 continuous) FM: range: 87.7-107.9, mono usable sens.: 9.3dBf (0.8uV/75ohms), 50dB quieting sens.: 13.5dBf (1.3uV/75ohms), Alternate channel selectivity: 80dB, SNR: 65dB, stereo separation: 35dB, capture ratio: 2.0dB AM: range: 530-1710kHz, usable sens.: 22.5uV/27.0dB CD: 8x oversampling @ 352.kHz, 1 bit DAC, freq resp.: 5Hz-20kHz (+/-1dB), THD: 0.008%, dyn. range: 95dB, SNR: 95dBA, channel sep.: 85dB. MD: freq. resp.: 20Hz-20kHz (+/-0.5dB), THD: 0.008%, dyn. range: 90dB, SNR: 90dBa, channel sep.: 85dB. Equilizer: 7 bands (centers): 63/160/400Hz/1/2.5/6.3/16kHz, boost/cut range: +/-10dB. General: Pre Output voltage: 2V, operating temp: 60C to 10C, power: 11-16VDC
Reviews:
User Manual: MDA-W890
