Brakes Make Noise When Stopping
Motsey
hi my is200 is sick again!!! :crybaby:
when i press the brakes there is nothing unusal untill the car stops and just before it stops there is a weird fart like noise
this is weird had the brakes,pads and disc's checked all fine rear caliper was sligtly damaged even got that changed and no difference the guy down the local garage is stuck aswell!! :unsure:
anyone got any ideas?
Sounds like the pads have got very hot at some point and now have a hard outer-layer at the point where they meet the disc, mine does this a fair bit
Don't know a cure other than replacing a perfectly good set of pads, don't know if you can re-key the pad's surface silghtly or wether this will damage the pad
hopefully it is that, in time will the noise stop, like when the top layer or pads rubs off and is it visabilly obvious like could i tell by looking at them?
i soo hope that is it would be a weight off my mind, just scares me everytime i brake thinking ehat if next time i dont stop!
I'd have thought it would evenually stop due to usage (but I don't use mine everyday, only few times a month, being an auto the noise is worse untill the pads warm up - usually within a few miles), not sure of the time required
Can't remember if there was any visiable tale-tail marks, been awhile but the pads do feel very very smooth and very hard (tap a small spanner on the pad and I got a solid sound), only the front pads did this, the rears where OK
I changed my front pads and the noise went so I knew this was the cause, now have a spare set for when they do evenually go
Hope this helps and puts your mind at ease
BR
Paul
BR
Paul
yes definately hopfully its the same problem, ill leave them as they are for the moment have a few things i need to do to the car first then ill get them changed.
has anyone else come across this?
-Thanks
  • 3 months later...
