Trust Air Filter
Hmmm...looks like a nice peice of kit! Any performance increase, or technical data about it.....have to see how it matches up to the likes of HKS...etc
Someone posted a picture of this kit last year.
It is available for the is200 but has a metal a metal intake pipe (bad for heat soak - hence loss of power), and does not have a cold air feed, although you could probably use ours.
Mark :)
Mark :)
well the so called "heat soak" can be easily solved with a piece of heat wrap if you are that bothered. But to be honest, for the negligable gains that you will get from the kit any slight increase in air temp isnt going to make any noticable difference anyway.
