90-92 Keyless Entry Conversion
I am not sure that I understand your question but I have fitted an alarm to mine that also links to the central locking and so arming and disarming also locks and unlocks the car. This is very basic on most alarms, is this what you mean? If not then what is wrong with the standard way of unlocking the car with the small button on the key?
Steve Birchall
Yes, this is what I mean, My keys have finally quit even with new batteries. I want a low cost way to lock/ unlock using an aftermarket device. Where should it be installed and how to wire it into the present system (91 LS 400)
I was told three years ago the cost would be about $ 360; the receiving unit must also be changed. I have been able to track down the necessary wires connected to the recieving unit that lock & unlock the doors. I am working on adding an aftermarket unit that will also unlock the trunk as well for a cost of $ 50. All the wires are in the trunk and not that hard to get to.
  • 4 months later...
