A Real Safety Issue
GWilso
Ill get straight to the the point
An 06 220D SEL-MM only had for 3 weeks
I've gone to select 2'nd gear it won't go try again to select again it won't, try again I think I've selected 2'nd raise the clutch and quickly realize its in 4th the car stall's whilst moving or negotiating a corner?
This has happened 3 times this week and once last week,
Please tell me this has happened to others and I'm not just becoming a very poor driver :crybaby::crybaby::crybaby::crybaby:
HELP
HELP
unfortunatly lots of problems with the IS220D manual 6 speed box,take it back to your Lexus dealer.There are a few other issues you may have a problem with:selecting 6th gear(does it grind/crunch?).Hand brakes not holding(seems to be later cars than 06)worth keeping an eye on though.Injector problems was a big issue,does the car knock when cold and get better when it worms up?
