Superchargers (other Types)
Right guys possibly silly question time...
I know anything is possible in theory but and its a big BUT, so here goes;
How feesable is it ot use superchargers of other cars, especialy as I see you can pick up Mini Cooper S ones very reasonable. So apart from the charger itself and a homemade bracket for it, Pipe work, intercooler and belt, what type of ECU would be possible for it.
Also anything else Ive missed shout up.
But as I said the big question is would it work on my IS200?
Any advice much appreciated
Dazza :question:
For the ECU it all depends on the boost you get if it is no more than 0.3 as produced by the TTE kit, you might not need a remap and get away with just an FCD other wise you will need a new ECU and potentially injectors aswell
Dazza :question:
No the mini supercharger is to small :P
The Mini charger is an Eaton M45 and the TTE one is an Eaton M62 the Mini one os designed for engines 1.6-2.0L so it does work but its right at its limit (the M62 is 2.0-3.0L).
A lad local to me fitted one but took it off again cause it wasnt too good.
:offtopic: Stav, i dont live near Warrington :P
