New Brake Discs
shanem
Hey guys
Im thinking of getting some new brake discs when i have to replace pads, which is pretty soon...
Can you give me your advice and opinions on which ones to buy etc? drilled or grooved or both? or just stick with standard? and if you could point me to some that you know are good then that would be great :)
Cheers ;)
Standard are good, but if you are going for performance upgrade, always go for groove.
The grooves will keep the disk clean and actually help the disk "bite" into the pad.
DO NOT go for cross drill disk as not only do you decrease surface area for the brake pad which will reduce stopping power, it will also crack under extreme usages. Hope it helps. :)
