Office 2007 Contacts
Rabster
im trying to get all my contacts from my nokia N95 8gb into my outlook
it wont let you drag and drop the VCF files into it
you can only convert 1 file at a time as standard into outlook
its winding me up now as i have over 300 contacts lol and dont wantto sit converting 1 by 1
cheers
with windows vista itputs them as windows contcts and for some reason that doesnt store numbers just emails and i cant work out how you change it to put them into outlook
That's weird, I had mine running fine on vista and xp.........have you set up in the nokia sync to sync with outlook 2007 and not with anything else?
Manually run WAB, highlight then drag all the vcf's across. The only issue is that it wants you to say OK but you can keep your finger on the enter key and it will fly through them. Then you can then export as a csv and then import wherever you want.
Other than that, you could script it in VB.
