Is200 Tein Coilovers ?
kris_t
With Tiens, yes i believe you need the top mounts as well otherwise they knock, i assume this is front and back.
as for how low, its up to you, i'd imagine stupidly low but then you have to consider the wear on other components.
Oh right, the dealer may have been able to get them with part no TD380-27706-00 - otherwise TTE could have supplied you direct.
The Tein's should be good though, will be interesting to hear how they are as not read much feedback on these apart from a guy in a monster powered Supra who liked them for road use :)
well ill give a acurate review when fitted and clear up the myth of knocking once and for all lol
some say if you put the oem mount back in th esame position they came off then its ok but others say
that it defo will knock
only 1 way to find out i guess
