What Is Needed
breet
40k service- this includes air filter, pollen filter, diff and engine oil changed, oil filter, washer fluid topped up, if the car has red coolant then this will require changing (if its pink then no need to worry for 10years/100k), brake fluid every 2years, the usual full check over and vsr.
if your not mech' minded as mentioned above then you could take it for a free VSR by lexus, but you could check a couple of things yourself- things to look for are front brake wear (especially if its auto) around 20k. check for the discs 'lipping'. the min thickness is 30mm. occassional leaking shockers, check for extreme dampness on the shocker legs. and yes as dj wozza has mentioned- tyre wear. apart from these there are no other major issues with a 40k IS.
