Tyre Pressure Help
enrico
HI ALL I NEED HELP TURNING OUT THE LOW TYRE PRESSURE WARNING SYSTEM ON MY 430 SC. IT IS A JAP IMPORT AND LEXUS WONT TOUTCH IT HAS ANYONE ELSE MANAGED TO GET THEIRS TURNED OFF? ALSO DOES ANYONE KNOW OF A COMPANY OR PRODUCT TO CONVERT THE T.V. FOR UK?
The unit is just under the gear shift plate you can just disconect the plug and that disables it.
Lexus wont disconect it as its a safety feature, which requires regular costs to maintain :arrrggg-matey:
Hi, I have had the same problem with my car and would like to disable the tyre pressure alarm as it is sounding constantly. Is it difficult to access the plug on the unit under the shift plate?
Guest inicol63
Very easy to do just lift up the arm rest and were the electric seats switch is wiggle that up and then move the gear lever to N and then be carefull when lifting out the wood inlay.
The ecu motor ynder the radio has two plugs going into it pull out the smaller of the two plugs i think it the left one and then replace items as you removed.
Job done.
