Engine Management Light
My qustion is what do I do about it ????
Sorry to hear this. Can you get the car to a garage and get them to hook up a diagnostic reader to your car? Get the error codes read and post them up- someone will know what the error codes mean and how to fix the problem.
i had this in the way back form the WIM meet..
im not sure if it was the Battery or bad connection on the coil packs..
i pulled em out and pushed em back in, checked the batt connection and its been fine since!
Should I rest the ecu and see if that sorts it first ???
Have not got much time to get it sorted if its coil packs !!!!!
if you reset the ecu you will loose the codes
but they will reappear if the fault does
try it for starters, never know it may clear itself
what ecu have you on the charger ? tte or hks ?
Yes did the spark plugs when we did the charger.
Went down to a garage and they did not have the equipment to read the OBDII codes.
Trying now to find a garage in Peterhead that can read the OBDII codes.
If not here will have to take it into Aberdeen but thats a 35 mile drive in limp mode.
if you really want i could post you my reader?
pm me if you want.
Have tried all the garages in Peterhead and no one can help :crybaby: :crybaby:
Ur having a laugh..... obd reader is basic equipment...... :ohmy:
Yes but they have said they do not have the dics with the program to read a Lexus one :crybaby:
stupid garages. it only cost £20-£30 for one i would advise to buy one as they help alot mate. if you do take to a garge they will charge £15 to read the code.
