How Do You Remove The Headlight On The Ls430
as it says - last night I made a right hash of changing a bulb, resulting in me deciding it would be easier to remove the whole headlight assembly than to continue fiddling - I removed the two obvious screws but found that it was still 'connected' somewhere around the wing.
In the end I managed to solve the problem without removing the headlight, but was wondering how you do it for future reference.
Have a look here ( sorry didn't see your year but this is for a 2003 model probably the same if not enter your year and body type)
http://www.toyodiy.com/parts/p_E_2003_LEXU...EAGKQ_8101.html
Hi, I am reliably informed that changing a headlamp bulb in this age car is quite challenging. Typical garage cost is @ £500 ( yes five hundred pounds ) per side and little of that is the bulb cost. And if the " motors " are defunct then the cost escalates to @ £750 per side.
The older models without Xenon bulbs are ( hopes ) less demanding.
http://bahamutcars.free.fr/workshop/LS_01-...ents/index.html
Repair Manual ( - 2003.7 ) / Body / Headlight / Removal
Page B0-8
Page B0-8
Wow - Fantastic link - Looks like I just needed to 'tug a bit harder' :rolleyes:
- warning only works with IE not firefox.
