Limited Slip Diff
The sport is the only model to have the LSD, if you have a sport, then you have it :)
Dont think there's any markings from the outside that will tell you.
You should be able to tell if you give it a bit of a slide about (off a public road!!) If you cant tell, then it probably wouldnt matter whether you have or not... :whistling:
I knew I'd seen this asked recently so did a quick search and found "steviewevie" had provided the following answer ....
See the vin plate, where it says "axle" there are 4 characters, e.g. A02A or A02B.
Check the fourth character - "A" means open (non-LSD) diff and "B" means LSD.
You can find the whole thread here ...
http://www.lexusownersclub.co.uk/forum/ind...showtopic=59200
Hope that helps.
TG
Its true sports had LSD's. but not all sports
Hope that helps.
TG
Thanks for that. my car has a lsd :hehe:
