Solhatt's Is 200
Solhatt
After looking trough a couple of thread and asking some question i made a list over things i want to fit/fix on my car :)
To do list:
Paint front bumper
€ 330:
Chips on bonnet need fixing:
Left rear door has a nasty scratch
€ 80:
Right rear door has scratches
€ 80:
Headlights are yellowish and need polish also want to fit xenon's, paint the inside of the lights and fit CCFL angel eyes (I saw your thread P.Lindblom :P):
Paint break calipers. would blue be a nice color?:
Replace antenna with a shorter/nicer one. What do you recommend?:
Tyre wear on the inside (yes i know it's a common problem):
New front seats? or is there any way to make the leather look fresher? :
Fit an arm rest (know it's hard to find but think i found one)
€ 130?:
iPod connection for the OEM stereo (I want a OEM look and the head unit still works)
€ 90:
Gear knob has a lot of scratches:
Compressor kit. € 2000?
Any suggestions? :D
May I suggest you add a shortshifter to your list?
so it basically just a shorter gear stick? i don't know i i really need that. Cons and pros?
What about the blue dash light convertion!
Yeah maybe. to bad blue is kinda used everywhere. It's mainstream
True they are everywhere, ive thought of doing this but would rather keep everything standard where i can.
Looks like i have to buy a compressor as well :)
If i buy a compress from uk and fit it in a car with left hand drive, would it fit whitout any big modifications? I have heard about the power steering problem. Do i only have to get some new pipes or what?
when you shift from 1st to 2nd the distance in between those two positions is called the throw.
a "short throw" shifter shortens the "throw" or distance between 1st and 2nd,
and subsequently between all the gears.
this is done by altering the shifter.
this can done by bending the shifter at an angle, changing the shifter center,
or, as you have assumed, making a physically shorter shifter.
it depends on how you go about doing it.
personally i believe the best option is the TRD short shifter kit.
the toyota/lexus/trd part number is 33530-SE100.
i am sure you can see the pros of having a shortened "throw" now that you know what it is.
