A Question About Gear Box
Very quick question about IS200 SE gear box.
Does the cold weather effects the way gearbox operates?
I know by default design, the gear box is a bit hard to use and it is not as smooth as it can be. This morning after driving less than a mile down my road, I found quite difficult to change gears where the gears didn’t go in place as they should. Eventually, after releasing the clutch, the gears started work fine.
Any ideas/comments would be greatly appreciated.
