Metal Wheel Valves
Pristine Wheels have recommended that I do not fit metal valves to my newly refurbished wheels as they will create a reaction with the alloys. What are peoples opinion about this piece of advice???
Do you mean valve stems or valve caps?
If you dont like the look of black valves, you can get a chrome plastic cover which slides over the top to tidy it up a bit. Failing that, you should be able to put on a 15mm stubby valve so its not as noticable!
Bruce
Just had to use a spanner and a pair of pliers to remove the alloy dust covers from my tyre valves where they had welded themselves to the stems. Obviously there was some sort of chemical reaction because a lot of white dust came out. If you must use them I would suggest a dab of vasoline on the stem and don't do them up too tight.
Bruce
I meant valve stems as the wheels have no valves having been recently refurbished.
